Draft shield
I’ve been having a hard time getting good z axis impact strength with ABS and Polymax PC. I tend to get worse results closer to the edge of the build sheet. Adding chamber insulation helps but I worry about damaging the motion system and electronics
I wonder if adding a “draft shield” feature in bambu studio would be a safe way to provide a warmer environment for high temperature filaments
Others tab, Skirt height, set it to however many layers you want.
Thanks, that works perfectly!
Thanks for this! I came here looking to offer this as a recommendation and found your suggestion. It works well.
But for one loop wide skirt (which is typical draft shield width), there is no enough adhesion to reliably keep it in place. Also, skirt is typically used for normalizing filament flow before printing, so having one loop skirt makes its first layer really bad, so it fails. Trying to make it contact with brim also does not work, it always keeps some distance. I would say, that skirt cannot replace the draft shield. The shield should have its own wide brim for good adhesion, be one loop wide, and still needs a skirt for having good first layer.
priming the nozzle for the first layer is done by the purge line, if you print a draft shield with skirts, it works quite fine, just dial in your settings properly and it does not detatch from the build plate
On a P1S, I got many problems too with eSun eABS+HS. This material is rather uncooperative as soon as you have important surfaces on the bed. It really curls like mad.
I tried many things, also pre-heating the bed to 100 for a long time to raise the chamber temperature. the high skirt as described is also a big failure as it warps and detach long before the end.
Finally, my solution it to create a draft shield in the model. (I use Freecad).
Either you have to make one body, using the “allow compound feature” (new in freecad 1.0), or you create it as a separate body. Then you activate internal/external brim to join everything together.
A feature request would be nice, but as it concerns mainly other brands of filament, I doubt that we ever get it.
