I’ve reloaded a few spools (using a Pastamatic) and have had some trouble getting the filament to stay in place such that it won’t later be an unwinding problem later for AMS. Tape is bad, hooking it into the side holes is bad and trying to just hope it’ll catch/lay tightly is frustrating.
A simple fix for me was to use a drill and put some holes in the hub. Pretty easy to do. I used some blue painters tape as a guide for where to make the holes. Drill inward straight, just adjacent to one of the internal ribs that divide the spool. The lever the drill over to carve the hole sideways. This helps make a lead-in slot for the filament. Then make a second hole near the other internal rib and lean it over to point the hole toward the first one. Seems to work in that it was tight enough for the winding to get started without as much trouble, an releases later when the spool runs empty (at least with one, so far)
