Drop to bed button for parts, negative space, modifiers, etc
Hello,
I want to suggest adding a button that allows you to drop parts, negative space and modifiers to the bed as described in this vid :vid here
If you right click and split into objects it will drop everything to the bed.
Doesn’t work for negative volumes and modifiers.
I agree with request.
This is a different goal than the ‘split to objects’ that has the effect of dropping all split part to the plate.
Something that would allow you to move any selected part/object when individually selected to the plate.
Personally, I would also like a toggle on the move option to use a build-plate based offset rather then the height being the centre of the group.
build plate off set is a great idea too!
can be used as a work around in some scenarios but overall inefficient of you only want to move 1 part, thanks anyway!
@JonRaymond - Why would someone want to split an assembly back in to objects just to assemble it again?
This is such a great request. Playing zed wars is one of the most tiring things I do in the software.
