I’ve found conflicting about this. Can you dry filament with this combo. I see nothing in Studio or on the printer that allows it. I think I have the latest software.
According to Studio, the AMS humidity is at 45%. That seems to be in acceptable range. What should i shoot for?
Figured out how to dry from the printer screen. How often do you dry? Every time you change spools? For how long?
I’d fish out the dessicant packs and replace and/or regenerate them if your closed ams is reading 45%. And consider adding some extra packs, there are designs on makerworld to find extra nooks and crannies to put dessicant into.
The humidity level you want to try to maintain depends on the filaments in the AMS at the time.
PLA? Probably fine at 45%
PETG? I would get worried if you are creeping past 20%, but <15% would be ideal.
ASA/ABS/Engineering filaments? As low as possible… but with those, you likely have another drying option, and all you need to do is pack your AMS2Pro up with desiccant to keep it at low humidity.
One note… if you pack your AMS2Pro full with desiccant using any of the printable options… remove the desiccant before running a dry cycle. Otherwise, you probably aren’t drying the filament as much as you think you are.
