"E3D High Flow nozzle can not print xxxx" Error - how to fix?
I get this error now on Bambu Studio version 2.8.1.55 “The E3D High Flow nozzle can not print ELEGOO PLA Silk” . It most certainly can. Not only does it print, but when I dialed it in, it prints exceptionally well. How can I get rid of this nagging? Nothing but roadblocks on this software lately. What gives? How can I turn off the nanny-state of this software? I know what works because I’ve been dialing in all manner of manufacturer filaments in on these E3D nozzles for MONTHS
Thanks!
I presume the warning is legitimate, but if you want to get rid of it, you have to edit the “filaments_blacklist.json” file in the %APPDATA%\BambuStudio\printers folder, and remove the following section:
  "name_suffix": "PLA Silk",
  "nozzle_flows": ["High Flow"],
  "model_id": ["C11", "C12", "BL-P001"],
  "action": "warning",
  "description": "Default settings may affect print quality. Adjust as needed for best results.",
  "wiki": "https://wiki.bambulab.com/en/accessories/e3d-hotend"
No guarantee it will print properly.
I’ll try this - I know all the PLA silks I have print great because I’ve dialed them all in using my E3D ObXidian nozzles. So at least to me - the warning is bogus.
Keep in mind that you have to perform this trick after each update.
Success!
Sadly it still barks the error and keeps me from slicing the file. Must be something else in there blocking it as an error vs. a warning. I’ll open a ticket.
