Elegoo ASA print quality
anyone have a good profile or settings that i could use for elegoo ASA, im having difficulty getting a good quality top layer no matter what i do it has little zit like dots on the top surface whether i iron or not, ive dried the filament change flow calibrated it and so far no success. its at the point where i might just need to take the loss and spend double on a Bambu ASA roll and hope that works?
if anyone could help it would be greatly appreciated :slight_smile:
I’ve not used BBL ASA in a very long time since I found Polymaker ASA. It print like PLA for me.
When I get the odd zit on the top surface and it’s not due to the usual culprits, moisture etc, I switch the infill to gyroid.
Hope it helps.
got much better results now thank you very much, now time to try perfect the ironing :neutral_face: hopefully that goes well!
What settings did you end up using? I’m about to print Elegoo ASA for first time and would be great if you shared your settings. Thx!
