Enable support only for one item
When I am printing multiple items on the same bed, how can I enable support only for one item?
You have two options: Either select the objects tab in the left pane of Bambu Studio to select a specific support setting for an individual object, or select one of the manual support types and use the support brush to paint all the spots you need support.
Select your item > Object tab > Select support (fine tune your support setting in this support tab too so its not universal)
I’m not seeing the “Enable Supports” line item when I click on a part. Under “Frequent” I see Layer Height and Sparse Infill Density only. Supports are enabled globally.
