With the new version 2.0.0.95 just released, the first bug I found was that the enter key on the number pad of the keyboard is not working. I can enter numbers but when i hit the number pad enter key, nothing happens. I have to hit the main enter key on the keyboard. see picture.
Same here. Corsair RGB keyboard
Having the same issue here with a Yunzi Y98.
Glad I am not losing it. I was trying to figure out what was going on.
Have you checked if this issue persists across different input fields, or is it specific to certain areas of the software? Also, does reverting to a previous version restore normal functionality?
I have tried using that key on changing size, cutting, movement, and rotating the objects and that number enter key is dead in the water on all of them in the new release of Studio… It works fine on the older versions of Bambu and also works fine with ORCA. I’m sure its a bug (or a forgotten line of language) in the new release of the Bambu Studio software, with all my testing as well as the other users reporting the same problem. Are you a fellow user or are you a Bambu Studio employee? I’m asking cause I’ve gotten no word from Bambu as of yet, addressing this problem.
Same here, using numeric keypad is second nature to me so the “enter” button not working is annoying AF, hope they will fix it soon
yep, known issue that I hope they fix soon, who even uses the numpad enter key in a field for entering numbers? silly ![]()
I run Bambu on several computers. All have this issue. Hope they fix it soon. It is driving me nuts. Several items I am not a fan of sofar on the the new studio. The prime tower is another one. At default the thing is huge!
Having the same issue on Mac but older version on PC works as it should. Big bug!
Sounds like a bug specific to the new version rather than your keyboard itself, since the main Enter key still works. You might want to check if remapping the numpad Enter key or rolling back to the previous version helps until they patch it. If you’d like to quickly test whether your keyboard keys are functioning properly, you can check it at space-bar-clicker-github-io
