Error HMS-0500-0500-0001-0007: what to do?
Today, when switching on my P1S on, it started to update to 01.08.02.00. So far, so good. But when trying to print out of Orca I got HMS-0500-0500-0001-0007. Recommendation is: update Orca. BUT: my Orca is up-to-date. That’s a good example of a deadlock.
And before you ask: yes, I reset the P21S to factory. To no avail.
Known issue?
[EDIT] After downgrading the device firmware to 01.08.01.00 it worked again.
My understanding is that this is due to the “MQTT command verification failed” added in 01.08.03.00beta/01.08.05.00. LAN Only Mode + Developer Mode works for my setup, but downgrading is probably a more flexible option for the time being.
Thx. That’s what I did. But still unsatisfactory. I’ll mark it a solution, though it is not really one.
Yeah Bambu’s been getting really into locking people out after years of exploiting the good will of the open source community.
It sucks but they seem determined.
I really thought, there’d be much more people using OrcaSlicer and Bambus, who are protesting this. This is breaking the philosophy Bambu stood for and why I bought it. WIll try to get rid of that printer ASAP.
Same issue here. I’ve activate LAN mode and developer option and it works now.
I think BambuLab must to create something to use OrcaSlicer or other slicers maybe developing a thirdParties API or whatever. I don’t like BambuStudio application I think OrcaSlicer is better.
The same story and it’s not funny. I downloaded the project from MakerWorld, print it from Handy Studio and got an error instead of printing. Pfff!
I’m having the same issue and you can imagine how happy I am (got my new P1S two days ago…)
Anyway, a more viable solution to me is from Orca, instead of using the “print” function, use the “send” function. That will save your file to the micro sd card on the printer, and you can print seamlessly from there.
This is probably the best compromise with least amount of steps unless you cannot access printer physically for some reason or if you really want to use the camera feature.
I recently update bambu studio to v01.10.01.50 and since then I haven’t been able to send prints to my P1S. I’m also getting a code on the P1S - hms: 0500-0500-0001-0007 I have tried many different things to try and salve the issue but nothing seems to work. I am able to send prints via the handy app but not from my deck top. I even uninstalled and reinstalled bambu studio to it’s newest version which made things worse i.e. not even connecting to the printer.
I’m at a lose here for what to do to be able to send prints via my deck top.
Any input would be greatly appreciated!!
I lost my printer in Bambu Studio a couple months ago. Here’s what Bambu customer support sent me:
"This issue may result from corrupt configuration folders. You can try to locate the Bambu Studio configuration folder (Click the triangle on the top left corner of Bambu Studio → Help → Show Configuration Folder), and delete the whole folder after backing up necessary customized preset files(Bambu Studio - user - account - filament). Please close Bambu Studio before deleting the folder.
Then, try reopening Studio to see if it works.
If resetting the configuration folders fails to solve this problem, you can try to completely uninstall Bambu Studio and reinstall it after deleting the whole configuration folder. This is likely to solve the problem."
Deleting the configuration folder fixed it back then. I don’t remember what software version I was at tho.
