Error: Print paused ?!
Since today my P1S always prints a few layers and then pauses… it says: “print paused by user”. But i didn’t do anything. When i press resume, the print goes on without any issue.
I did not change any settings. Untill yesterday it worked perfect.
Any idea? Thanks for your help.
Seit heute wird jeder Druck (bereits 4 hintereinander) nach wenigen Layern pausiert. Es erscheint die Nachricht “Druckvorgang wurde vom benutzer angehalten”… Dabei habe ich überhaupt nichts gemacht, ich war nicht einmal im raum :wink:
Wenn ich auf Druckvorgang fortsetzen klicke, geht es ohne Probleme weiter. Bis gestern gab es diesen Fehler nicht. Ich habe keinerlei Einstellungen verändert.
Hat jemand eine Idee? Danke für eure Hilfe.
Do you have any residual “pause at layer” settings in your slicer?
Is there any sadists with access to the pause button?
Have you observed the printer go into a pause or only later discovered the pause?
  1. Do you have any residual “pause at layer” settings in your slicer?
  2. Is there any sadists with access to the pause button?
  3. Have you observed the printer go into a pause or only later discovered the pause?
to 1) no
to 2) no
to 3) both. The first time, i wasn’t nearby the printer and saw it idling when i came back. Then i tried three times and stayed near the printer. After one, two or threee layers the toolhead drives to the purgebucket and the printer pauses. The Bambu-Handyapp says, that the print was paused by user and i can klick to resume.
I’m having the same issue. It just started a few days ago. Otherwise it’s been printing fine for a month.
I solved the same Problem 2 days ago. My Magnet Cover at the Printhead was not perfect in Place because the cable was between the magnets. After attaching the cover in the right spot it works perfect again.
I just checked my print head and its attached correctly, nothing in between the magnets. It started happening after the last firmware update.
I am having the same issue right out of the Box.
Is there any new findings?
After a few weeks (two firmware updates in that period), the error was gone… but i still don’t know why und where it came from
I did have that issue recently when refill spools were trapping the filament in the filament. I would have expected the ams motor overload error, but in the case of filament being trapped at the rim, this is what triggered in my case.
Firmare 01.06.01.02
Filament unloading is not possible.
Nozzle heats up to 150 degrees, then stops and cools down again.
When printing, the nozzle heats up to 260 degrees without any problems and prints (briefly).
I also cannot change the language.
Resetting to factory settings does nothing.
Does anyone have any ideas?
I my self recently (aka today) was in a middle of a print. Nothing, absolutely nothing was a factor to pausing the printer. My pc wasn’t on, my phone was not in Bambu handy. But my printer stopped with a message. “ print paused by user” mid print. And I resumed the print. 5min later another pause with “ print paused by user”. Could this be a sign of hacking? I am genuinely worried and temporarily be using manual sd card print and will not be connecting my printer to my network. Does any body have an answer to this? How often do Bambu printers get hacked.
I’m a new user & recently refilled the filament for the first time & I’m getting the same error. Print paused by user. It’s happened a few times now. I’ll check the hotend when my print finishes.
