I’ve been using various PLA filaments with good success so I thought I would try using ABS as I need to print something that will be in direct sunlight a lot.
I first tried printing a few small parts and these came out well. I’m now trying to print some essentially large boxes 250mm x 115mm x 10mm. The first attempt I printed 2 of these with the largest side flat on the bed, this did not come out well, the first and last layers had an over hanging lip, but more importantly everything on the outer edges of the bed bent upwards during the print causing the piece to be curled up along 3 of the edges, this then caused the top layers to get messed up as I assume the print head was pushing into the top of the print.
I then thought it may be better to print these on their end, 250mm x 10mm side on the plate, and while this came out much better I still have quite a bit of deformation. If I put one end on a flat surface and hold it down the other end is 5mm off the surface, its is the side that was on the baseplate. The vertical sides have a slight concave deformation, the top and bottom protrude further oud than the middle, but only by 1mm or less so this is less of an issue.
I know that ABS is a more tricky material to print with than PLA and I guess I am going to the extreme or trying to print something straight and flat that it half of the area of the print bed. But I am hoping I might be able to get a bit of a better result after tweaking some of the print settings. The trouble is I don’t know what settings to change.
I am using the eSUN profile I downloaded for bambu printers from the eSUN website.
I am guessing the issue I am seeing is that the material is shrinking as it cools which is mostly along the print bed. I’m not getting any other issues with the print. If anything I’m seeing a little too much bed adhesion, but nothing major (don’t have any glue sticks yet though).
What setting(s) would you recommend I change?
P1S Printer, 0.4mm nozzle
0.2mm standard @BBL X1C
wall loops 2
top shell layers 5, 1mm thickness
bottom shell layers 3, 0mm thickness
infill pattern rectilinear
sparse infill 15%
pattern grid
Filament settings:
nozzle 260c
textured plate 100c
no cooling for 3 layers
min fan 10% 30s
max fan 50% 3s
keep fan on true
slow printing false
force cooling true
aux fan 0%
Print file
solid.3mf (24.3 KB)
Thanks for any help
