I have been having a serious issue with my A1 - it has been purging an excessive amount of filament every swap, and Bambu support refuses to acknowledge this issue. They keep dismissing it as regular function. Per swap, my printer flushes about 0.11g extra than what the slicer estimates. I have been speaking with support and talking to other people about this issue for a while now, and I was hoping the community here could help me gather more information. I will also say that some of the people that I have been talking to also experience this issue on other printers with the quick-swap nozzles, like the P2 and H series printers. I only have a P1 and an A1, and I haven’t observed this on my P1.
If you can, can you please observe your A1, H2, or P2 printers in the same way? Before sending a multicolor print, take note of the estimated flush and number of swaps. When it is done, weigh the flush and compare. It would really help me understand if this issue is far spread, or if it is only affecting me.
Here is some of the data I have collected and tabulated so far. All of this data was collected from prints sent via Studio on my main PC. However, I do test Handy and other PCs below. I will also go into detail about other experimenting/research and my communications with Support up to this point below the table.
| File | Swaps | Calculated Purge | Actual Purge | Difference | Extra/Swap | Flow Dynamic? | Tangle Detect? |
| C:[…]\Documents\Bambu&3D=PLATES READY\shark-elephant-14hrs.3mf | 90 | 2.00 | 12.65 | -10.650 | 0.118 | X | ✓ |
| C:[…]\Documents\Bambu&3D=Purge Calibration=PURGECALIBRATION.3mf | 13 | 0.00 | 1.25 | -1.250 | 0.096 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore=Games\CactiChess - Roll up Cactus Chess Set\CactiChess.3mf | 78 | 9.37 | 16.42 | -7.050 | 0.090 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore=Games\PlayBook’d Chess.3mf | 31 | 0 | 4.56 | -4.560 | 0.147 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore=Games\PlayBook’d Chess.3mf | 31 | 0 | 4.45 | -4.450 | 0.144 | X | X |
| C:[…]\Documents\Bambu&3D\Cinderwing=Tadlings\painted tadlings.3mf | 96 | 18.99 | 31.14 | -12.150 | 0.127 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore\Morning Glory Magnets - Ivy Fridge Magnet - Flower Magnets (1)\1-Easy print 3mf - Morning Glory.3mf | 20 | 2.67 | 5.27 | -2.600 | 0.130 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore\Morning Glory Magnets - Ivy Fridge Magnet - Flower Magnets (1)\1-Easy print 3mf - Morning Glory.3mf | 20 | 3.66 | 5.95 | -2.290 | 0.115 | X | X |
| C:[…]\Documents\Bambu&3D\ForgeCore\Morning Glory Magnets - Ivy Fridge Magnet - Flower Magnets (1)\1-Easy print 3mf - Morning Glory.3mf | 20 | 2.37 | 4.69 | -2.320 | 0.116 | X | X |
I first observed this issue when I was printing a plate with 209 swaps, and a calculated flush of 16.69g. The poop bucket seemed to be much more than that, and it weighed 44g. This is creating an excessive amount of waste that I could have better planned for had the slicer (or my printer) been more accurate.
I also ran a purge calibration, which sets purge volumes to zero, but it was still purging more filament than expected. For a 0 flush, there is normally just a tiny small thread of filament. But on my A1, I was seeing full sized poops, each weighing about 0.11-0.12g. So in reality, a 0 flush is impossible on my A1. When I run this same purge calibration on my P1, I get true flush volume results. When comparing the same color swaps on the A1, it results in flush values about 75 less than what the P1 reads.
I next tested a few other variables with this same purge calibration file: From the Handy app, from Studio on my normal PC but with flush volumes set to 1, and from Studio freshly downloaded on a computer that has never had the software on it. They all performed similarly.
At this point, Support had provided me with custom G-Code which did not affect my results for the purge calibration or any other standard multicolor print. I was still seeing very excessive purge.
My concern was transferred to an engineer, and they told me:
Hello,
Thank you for your patience, the engineer just got back to me.
We have reviewed the ticket again, kindly note that the flush process during the complete printing process cannot be waived for the A1 series and the H2 series, which have the auto flow calibration function.
If you want to reduce the flushing filament when you exchange the color, you can kindly refer to the Wiki to check in detail and further adjust the G-code: Disable unloading and flushing to save filaments when printing the same material
Kindly check if it works and let me know if there are any further issues, I will help you further check.
Thank you for your cooperation and sorry for the inconvenience caused again. If you have any other questions, you can contact me at any time, I will always provide you with the best service!
Best regards,
Bambu Lab Customer Support
Next, an online friend of mine who also has an A1 ran a CaliDragon, and got the following results (we measured total print weight instead of just purge):
Total swaps: 133
Friend’s A1 Slicer Results: 77.02g total
Friend’s A1 Print Results: 82g total
Summary: 5g more than estimated
She also ran this file on her H2D and X1C and got -2g and +5g estimated, which is reasonable over 133 swaps. We also confirmed we had the same software version on Studio and firmware versions on our printers.
I downloaded the same file from the same link and had identical settings, and printed the model on my A1. These are my results:
My A1 Slice Results: 73.55g total
My A1 Print Results: 84g total
Results: 9.5g more than estimated
Almost double than what my friend experienced.
The next step in research was that my friend sent me the exact GCODE file she used for her A1. She showed me her slicer results before exporting the gcode and sending it to me.
I sent the gcode to my A1 via SD card:
Cali-Dragon_2-Color.gcode.3mf
Friend’s A1 Slicer Results: 76.04g total
My A1 Print Results: 89g total
Summary: 13g more than estimated
Clearly something is not right with my printer. This is very abnormal.
Next: I FACTORY RESET my A1, did NOT add it to wifi, ran the required machine calibration, and sent the SAME GCODE file via SD card:
Summary: 13g more than estimated – identical results to the previous test.
An additional 13g over 133 color swaps averages out to an additional 0.1g of purge per swap. This is a consistent amount that I have been experiencing and reporting. This adds up exponentially over larger prints.
I sent all of these CaliDragon tests between me and my friend to support, and included this message:
Your response does not address the issue I am having of excessive waste 'compared to the slicer.
I have also included gcode and 3mf files mentioned in the document.
My friend has also observed more conservative waste when doing the purge calibration tests that have been mentioned in previous messages in this thread.
Automatic flow calibrations have been turned off for all of these prints, so using that as an explanation to my problem is unacceptable.
And this was their reply:
Hello,
Thank you for your reply and sorry for the misunderstanding.
I just checked the results and the PDF file with the engineer, kindly note that there are more steps for the A1 series to process before starting printing or during printing, which could cause more flush. For example, since there is no filament buffer on the A1 series, there could be a preloading process to detect if the filament has been extruded.
The other detection, such as the Nozzle Clumping Detection function, will also cause more flushing.
The flush mentioned in the steps above will not be included in the data in the Bambu Studio, hence the result may be different.
I can totally understand your feelings and I really want to help you further, I will note the inquiry and I will transfer it to the engineers. I will mention the importance of the inquiry to them and check if we can adjust it further. Kindly keep following our official website for the latets update.
Best regards,
I had replied:
I am positive that the only printer settings I had turned on during these tests outlined in the PDF (before and after the factory reset) was * auto-recovery from step loss. I’m looking forward to your response.
*I had also said tangle detection, but I double checked. It was off and sent a follow up reply correcting myself along with “I would like to reiterate that my friend and I ran the exact same gcode file and got 2 completely different final weights.”
Their response was pretty baffling:
Hello,
Thank you for your reply and sorry for the misunderstanding again.
Kindly note that some steps I mentioned earlier, such as the preloading process, are included in the firmware default setting. Hence, it will turn on in each printing.
As a warm reminder, since I really want to help you further, I have noted the inquiry and I have transferred it to the engineers. I have also mentioned the importance of the inquiry to them and checked if we can adjust it further. Kindly keep following our official website for the latest updates.
Best regards,
I had quickly said that that explanation was beyond absurd and asked for documentation or a source claiming that environmental factors can affect purge.
A senior technical support representative took over the support chain and apologized for that rationale, but also added:
Regarding the issue you raised about flushing volumes, I would like to explain that the weight displayed in the Bambu Studio Preview interface refers solely to the filament weight required for printing. However, the actual generation of flushing volumes involves various processes: extrusion during loading, a certain amount of purging to ensure correct extruder loading, Flow Calibration where the eddy current sensor tests filament through flushing, and flushing at the wiper position during Tangle Detection to confirm the presence of a tangle issue.
This part of the support chain just starts to get cyclical. I asked this Senior to please review the previous information I had shared, including the identical g-code that was ran and the largely different results.
Dear Customer,
As previously explained, A1 requires extrusion of filament to determine if printing can proceed normally. The pre-extrusion action is necessary and is written into the firmware, thus cannot be modified. Variations are expected between different machines and filaments; this is a normal occurrence.
Kind regards,
My reply:
why does Bambu consider it an acceptable outcome for the same model of printer within a product line running the same gcode using the same filament to have waste differences of .1g per filament swap? Reminder that on a multicolor print this can easily total 90g on a single plate, leading to excess waste generated by a single printer of 1kg every 11 plates printed…This lack of urgency and blatant dismissal to my issue will be shared with the community and other outlets.
They responded:
Dear Customer,
For printers of the same model, perfect uniformity cannot be guaranteed. Slight deviations are normal. In terms of pre-extrusion, factors like extruder or nozzle clogging leading to under extrusion, or excessive resistance in the PTFE tube, can cause increased flushing volumes during pre-extrusion. These are uncontrollable variables. The machine needs to ensure data integrity before undergoing testing to ensure proper printing functionality…
Kind regards,
My reply consisted of the table I have provided at the top of this post.
I am still collecting data, but please explain why my A1 printer is consistently purging more than estimated by the slicer? How do I fix this? This is creating an incredible amount of waste that I cannot predict, affecting both my inventory and pricing.
Their reply:
Dear Customer,
Thank you for your reply,
We are unable to analyze the data you have provided at this time. As previously explained, during operation, the printer may perform flushing operations beyond the slicing process, such as preloading. These are all normal occurrences.
Kind regards,
