Experience with PEI filament? Chem resistant material recommendations?
This is more of a curiosity question since PEI filament is clearly an industrial product well outside the specs of a consumer FDM printer.
I have a project where I need some chemical-resistant properties. ASA is the one that keeps popping up in my research, but the endorsements aren’t exactly confidence-inducing. In one such blurb I read regarding its resistance to gasoline, the text said the following:
ASA is known for its excellent resistance to chemicals, weathering, and UV exposure. It’s often used as a more weather-resistant alternative to ABS. While it’s not completely impervious to gasoline, it generally holds up better compared to ABS.
That’s not exactly a ringing endorsement, since gasoline is precisely one of the chemicals my project may be exposed to. So if anyone has experience with filament that can withstand gasoline or diesel and other combustible fuels, I’d really be interested in your experience.
______________________________________________________________
As I dug deeper, the recommended filament that keeps popping up in search is PEI. Aside from the fact that this stuff is $8/oz, I’m only finding one or two manufacturers. It appears to be a product geared towards specialized industrial knowledge and specialized 3d Printers.
https://www.amazon.com/Ultem-Filament-3DXTECH-1-75mm-diameter/dp/B01M0N7GI2
Here’s an interesting video on the only product I’ve found so far that’s spooled to go into FDM printer.
Check out these specs. In the video they say that it works best in a heated chamber of 220c :face_with_crossed_out_eyes: Why stop there? 20c more and your printer can double as a Pizza oven. :pizza::joy:
I’m assuming that anyone who works with this class of material is in a professional class well outside of the consumer class of printer enthusiasts, so I am very curious as to how that world lives. It’s kinda like watching guys who drive around in $2 million sports cars that I can never afford, but it sure is interesting to watch.
I did find one printer that they advertise that is purpose-built for this and for poultry sum of 125 X1 Carbons, it can be yours. Hmmm… I wonder if we pool our resources, perhaps we can negotiate a group discount. :grin:
You can always print a cylinder or bottle in ASA & pour gas into it as a test.
I would print a potion bottle myself as it comes with a lid.
PPS is resistance to most things, but will be somewhat hard to print, will have to be super slow… also $$$.
Hi.
I would prefer continuing on the 256mm3 chamber and being able to print high-temperature filaments. Not that I need it, but I would love to have the possibility to do some tests.
On topic: PA6-GF30 is (or at least was) the standard material for car fuel rails.
Maybe lower blends, such as BL ones, will work, too.
print it in pla to get the shape right, then send the file it to a specialist material printer.
