Does anyone have experience with SUNLU Wood? I would be interested in the Filemant profile.
Kind regards
Kind regards
SUNLU have two different Wood Filaments.
My one had max. 190°C temp.
Over 200°C it smells very dangerus and you can often see smoke.
Generic PLA Profile and set the temps down to 185°C works perfekt for me ![]()
Thanks a lot. Iâll try it in the evening and come back with the results.
Yes, good and important point! The right temperature is printed on the label. Mine was labeled with âbetween 205 and 215 degreeâ.
Hello,
here is the promised feedback.
The specs from @print.in.3d were great. The filament that I use is printed at 205 to 215 degrees.
The result is really good. I still have to work on the infill.
Thanks to @print.in.3d @mampfiee
I love the wood prints but stopped doing them a couple years ago because it gums up everything it touches. It creates a residue thatâs like sawdust.
One question: Do you know, how much percentage of wood your filament contains?
@chopomatic Letâs see if this is still the case with the current filaments.
it shows 25% on the package
Ah, okay. Mine shows 10% on package. That maybe the reason for the different temperatures. ![]()
I havev the 205-215 sunlu wood too and was wondering if anyone has done any experiments to âslowâ down the processs, to allow the wood to âburnâ a little (not burn⊠but you know what i mean) - to get darker effects etc. My âWoodâ colour is a very light brown , almost tan and I prefer more darker look etc.
No, I havenât tried to âburnâ the filament to get a darker look. Butâs an interesting point. Is it possible? ![]()
Some woods will start to scorch at temperatures as low as 235°C, but they require much more heat exposure time than the short period it takes filament to pass through a nozzle. The plastic is more sensitive to heat than the wood fibers, so it dictates the acceptable upper temperature limit. Burnt plastic is seldom attractive.
This is what i would have thought too, will try and find and link the article etc, could be old info, poorly worded , or I just remembered it wrong ![]()
Hello. I use temperature between 190ÂșC to 195ÂȘC with your configuration too, changing only retraction distance and was succesfuly with SUNLU PLA Wood. Thanks @print.in.3d and @mampfiee ![]()
Do you need a hardened steel nozzle for wood filament?
For me not, I used the original nozzle who comes with my P1S because itâs made of stainless steel.
Technically yes, but i have used the stainless steel 0.4mm one with no issues and print quality is amazing. You might want to choose bigger prints if you want a really detailed one.
