So I’m trying to save the gcode file to the sd card so I can keep it saved and reprint using the external spool as needed. When I use the Export to G-code file and try to print, it looks for the first slot in the AMS. Is there a setting I need to set for the gcode file to NOT use the AMS and instead use the external spool?
***Correction. It seems to use the last AMS slot that was active as I tried this on my 2nd printer which last printed with AMS Slot 2 and when selecting an exported gcode file, it started to use the 2nd slot.
