Extend the nozzle load line
Does anyone know ■■ to expend the nozzle load line?
I’m having an issue on my new X2D where is barely has enough time to prime the nozzle printing the load line. This causes the filament to float around the chamber and affect the prints.
I’ve changed the length of it on my P1S, but checking the machine Gcode for the relevant section the X2D’s is very different and I don’t want to cause issues by changing things blindly.
See the red circle for the issue I’m referring too:
It’s in the X2D startup G-code, should be the “L40” bit at the end of the highlighted line.
Note - if you’re going to make it a lot longer, shift the starting point further to the left as well to compensate.
The other option is changing the E12 value back up to E20 - like in the line that was commented out. That will increase the extrusion amount.
