Extender cables for those two wires
So when you remove the PTFE tube and those two screws and lift up the inside piece of the AMS there are two wires one must disconnect. Does anyone care to post a couple of Amazon links that point to what would become an extender cable for each?
Thanks!
Isn’t it easier to solder some wires instead of put two more plugs on a cable ?
He may not have the soldering iron, skills, or the inclination to do that type of work. Nothing wrong with buying extension cables.
In no known universe, is it easier to make a permanent modification (as you suggest) than to add an extender cable!
Also, not inclined.
This. 20 characters? Whaaaa? :grinning:
Could a member of the Bambu staff provide an answer to this, please? Thanks!
