Extracting Models from a .gcode.3mf File
Hello,
I am struggling right now with an old file from Bambu Studio. I no longer have the original file, but I have an exported file that was on a Micro SD card for printing. Whenever I open the file in Bambu Studio and attempt to change any settings the whole model disappears. Is there any way to extract just the model or delete the cached settings that are contained in the file so I can re-arrange the parts or change my settings.
Thanks
Usually you can right-click on your model in the “Prepare” view and click “Export as one STL”. You can then save just the model to disk. If that does not work, perhaps you can try opening the file in Prusa/Orca slicer and try the same there.
Issue is upon opening the file it jumps straight to preview and won’t let me go to prepare.
Ah that is annoying. If that also happens in the other PrusaSlicer/Slic3r-based slicers it might be worth it to give Cura a shot (should also allow for STL export).
I hope someone can contradict my post and provide a solution, but I did extensive research on this topic and concluded that it is not possible if the 3MF file does not contain an embedded STL.
Here’s a dirty little secret about 3MF files: they are actually renamed ZIP files with a specific folder structure as defined by the 3MF consortium as defined here: (Specification - 3MF Consortium). If you change the filename to .ZIP, you can explore the folder structure defined by the 3MF consortium. G-code files and STL files are stored separately in the 3MF archive.
What you can try is changing the name of the 3MF file to ZIP. You should then be able to extract the file using your favorite archive tool or Windows extract-all command. Navigate the folder structure to search for an STL. If it is not there, then the archive was G-code-only, meaning that the file was printer-specific. As far as I have been able to determine, nobody has written a reverse-engineering piece of software to revert back to an STL. Again, I hope someone can say otherwise.
Yeah, it seems as if the file contains a file with the extension “.model” as well as the configs for the print itself.
That .model extension if memory serves correctly is actually a Gcode file. But you might try simply renaming it as a .STL and try your luck. I never had any luck.
When I add STL to the end it just becomes .stl.model
Never mind I figured out how to change the extension. “No geometry found”
Unfortunately there is no geometry in the gcode versions of 3mf files.
In terms of transforming gcode back into models - there are blender addin’s that can read in gcode and create a model - however the models it creates consist of loads of little lines that represent the filament extrusions.
It might be possible to remesh them back into something editable - or at least use the generated model as something you could trace over to recreate the model.
Meybe this can help you:
GCODE to STL Converter Online (Free) | Convert 3D
Never tried myself thought.
My friend, this is not helpful. Anyone can use Google and post a random site. This is one of those plethora of sites that advertises they can do anything except… they can’t. All they want is your email address. The site does not function as advertised.
There are so many wrong assumptions in your message…
I’m not going to argue with you, Olias my friend. Life is too short.
Have a nice day.
This has saved me in the past, but you do need another slicer that I hardly ever use.best of luck.
Very promising direction, thanks for sharing! But I tried it and Voxelizer (FAB, v3.0) would just close every time I would try to ope the .gcode file extracted from the .3mf.
Any thoughts anyone?
Thanks,
Matt
Hi, i tried to rename a gcode.3mf file, or open it with 7zip, → not an archive. Can somebody advise? a normal 3mf works fine, but i wanted to check the gcode what Bambustudio made. thanks :slight_smile:
Welcome to the forum.
I have a post with step by step instructions.
I know this is a bit late, but for anyone with the same problem, you can take the G-code into a software such as prusa slicer, from which you can export as an OBJ file, and then opening that OBJ file a second time lets you export as an STL.
I was fascinated by this because it represents a solution to the ongoing problem of converting G-code that, short of paid software, has defied an open-source solution. I tried this, but I found no way to import a Bambu Studio G-code file into PrusaSlicer. Attempting to load a Bambu-exported G-code file as either G-code or 3MF produces the following message:
Have you tried this and can you walk us through it? It would be great if could be may to work.
If you rename the gcode.3mf to zip, then unzip it, you should find some .gcode files. You can then drag them into prusaslicer, and then export them from the gcode viewer as obj.
The obj files are pretty complex - I tried editing one in Blender as gave up as they were too detailed.
