Extruder Clog continuously problem
For the last two days I can’t print anything. While it starts to print normally, suddenly a filament sticks inside the extruder and clogs. I have changed both extruder and hotend. I have also done calibration. I think something is blocking the thread. I wonder if the AMS is to blame on the power supply
Have you tried printing from the external spool holder?
Yes. It works fine. I think that all the problem is the spool that is not in very good condition (not properly unfolding) But i m not sure. I just print a piece with no problem but i was watching and helping the ams all the time
I looks like you may be experiencing heat creep issue where the the filament (mainly PLA) is getting too hot and becoming deformed causing your pull back issue. Try printing with the door open or lid off or both especially if you are in an area where the room temperature seems to be hotter. There are many posts on heat creep in the community forums.
From my experience, this jamming is probably caused by printing PLA or other filaments that soften at low temperatures with the door closed.
I often see people printing with the door closed to reduce noise during printing.
Typical appearance of heat creep where the filament gets too warm above the hotend entry thus becomes compressed and stuck between the feeding gears and the hotend entry unable to move in either direction.
possible root causes: ambient temperatures around the extruder high; very slow print speeds; high retraction values
I’ve noticed that it doesn’t always happen. That’s how long I’ve been printing normally. Yesterday on a certain plan this started doing the same thing to me. The weirdest thing is that it always does it at the same point in the print. While it starts normally (and with color switching) it reaches the point before ironing a level, it goes to the prime tower to clean the head and after that it sticks in the extruder the small part.
I had the same problem but somehow fixed it.
I uninstalled Bambu Labs including config files then reinstalled the software.
I reimported my model into bambu studio instead of using the .3MF file that had been saved before. I also did a factory reset on the printer. My best guess is somehow the print file or the printer became corrupted but once I did all of this the problem is gone. I just dont know what actually fixed it.
apparently it’s because of the heat creep, and as far as I know installing a extruder cooler can immediately resolve this issue. I got myself a one from x2hammer just fyi
