Extruder stuck?
after replacing the extruder motor, gears, nozzle, filament buffer, plate, I am having a new issue with the extruder using both the ams and external spool. The extruder will push the filament out to a certain point then stop. No problems retracting. Any thoughts? I have adjusted the extruder tension screw in both directions, with no luck.
Sounds like overloading of the extruder motor.
Were you having this issue before?
When powered off, do all the extruder rotating components move smoothly?
Yes, I was previously having extruder issues. Bambu support sent me a new extruder motor, I replaced the gears and everything else on my own. Could it just be a bad sensor now? Or maybe another motor issue?
To clarify, plastic leaves the nozzle successfully, but stops [for some reason]. Or that the extruder takes the filament, pushes it to a spot within itself that stops and stucks, and no plastic leaves the nozzle?
Hi!
I think I’ve got a similar problem. My printer (2 years old, not often in use) had never caused a problem. Now I wanted to start a print, it worked for 1-2 layers but stopped. When I try to print it again, it doesn’t work at all. The filament comes to the extruder, you can see this, but than it pulls it back, completely, tried it again, …
I tried different things… to clean the noozle, I tried to push filament trough (manually at 250°) and it worked fine. I cut a bit of the PETG tube, checked all other tubes - everthing is fine.
I tried to rearrange the filament inside the software and tried to print just a test with 1 color, original Bambu filament basic. It worked fine for a long time. But when it started the 2. print on the same plate - the problem came again. And now it doesn’t work again.
Does anybody know how to solve this? Or what the problem could be?
I can tell you, I replaced every part and sensor in the extruder/housing until Bambu just replaced the entire printer. I had no luck.
Hope you have more success!
