Finally got the cutter arm off and the extruder out and torn down but the filament will not either come out the way it went in or go on through. Is there a video or wiki on taking this apart further?
Glad to see that you got the cutter arm off.
There is a Wiki with a video: Extruder clog | Bambu Lab Wiki
I see you have the gear out, is the filament stuck in the filament sensor ?
if so I have not seen that before.
That’s what that is? I was unaware what that section was. It is completely jammed, I got a small pick in from the inside and attempted to push it out to no avail. I’ve tried everything except heat and chemicals which I think wouldn’t go well for the longevity of the part. The other times I had an issue in the last few weeks there was just a tiny fragment in that was easily cleared.
