I have a bit of a head scratcher. Maybe one of you smart guys can help figure it out. I am getting an under extrusion type issue that looks a lot like a flow dynamics calibration problem. See attached pictures. At first, I thought it was the new filament I was using for the first time. However, when I unloaded it and put it onto a different AMS slot and reselected a generic profile it flowed like butter. Cool, problem solved, I thought! A day later, I put a different roll of filament onto my only empty AMS slot (#4), and again I have the same ‘under extrusion like’ issue. I am using non bambu lab filament with the generic PLA settings, which work great on every slot except 4 right now. Everything worked good out of the box. The issue seems to have started when I tried to load a filament onto slot 4 during a print, which apparently AMS lite can’t handle. But all settings look good and I see nothing that would be causing this.
Also, every time it has happened I get an discontinuous (dotted or dashed) test line prior to the print. Second to last picture.
Thanks in advance for any suggestions!
