I can’t print the Toothless FULL BAMBU with or without support. I can’t get passed the first layer without the initial parts, legs and part of the tail, come loose from the heat bed.
I am new with this printer and I am about to give up with it.
Sad…
Wash your build plate under hot water with Dawn dishwashing soap. Do not use hand soap, do not use rubbing alcohol. Rub it in really good with your fingers, rinse it very very thoroughly. Use your fingers to wash it off under the hot water until it feels like sneakers on a basketball court. When you rub your fingers on the build plate while it is still wet, if it feels slippery it is not clean enough . Dry the build plate off and don’t touch it at all with your bare fingers where the print will be .Next try and bump up your bed temperature 5° C. It should work
You have provided no details which people can use to help you troubleshoot. no print bed, no filament, no adhesion aids, no settings. literally nothing.
Now with zero information I can recommend turning on a raft for any print with many small points of adhesion on the bed, Wash the bed with soap, then use the glue, additionally use steel wool to scuff the build plate (masking tape off the front information section so you don’t scrub the QR codes.)
