Failed print for A1 mini
Hi
We’re using the A1 mini and AMS lite.
We had an unsuccessful print using PLA Cobalt Blue filament.
One of the fins of this whale model snapped at 98% of the print and then the printer tried to print in thin air.
Does anyone have any advice?
Thanks!
Did a support on the other side fail, it’s hard to tell with your pic.
Fails happen sometimes.
It could be a lack of support, it could be bad luck.
Hi Lion7718
Yes the fin on the far side snapped at the base by itself 98% into the print.
You don’t have a pic of that side…??
If not, can you slice the model as you did before & post a pic of the other side showing the supports…??
Sorry - no I don’t my son quickly whipped it off the plate!
Is it possible to change the thickness of each layer, do you think that would help?
If you can’t post a sliced pic from BS, can you post a link to the file so I can look at it.
EDIT: Is this it…??
Reading the reviews, there are a lot of fails. From what I gathered, you have to slow the speed way down & add more supports.
Try printing this file & see if it’s any better.
SkyWhale-FIX.3mf (1.9 MB)
Yes that’s it! Thanks for the extra info about the reviews - you are very kind!
Thanks again @lion7718 that is super helpful - we’ll try that!
Hey @lion7718
That new file worked a treat!
Super kind of you to help out and my son says a big thank you!
