Failed to cut the filament. [0700 8001]
I’ve changed out the little blade, which doesn’t look dull. I’ve only had this printer for about 36 hours at the time of this failure… With only a few successful prints. I also can’t open a support ticket in the mobile app but I suppose I should post that separately. I am open to any ideas. A user on FB suggested clicking the load button in the mobile app but that also doesn’t work. My print is 99% with 4 minutes to go so I am REALLY hoping for an answer that saves it.
It is disappointing this has not been addressed. I am having the same problem.
Welcome to the forum.
This post is 2 years old. There are lots of other posts that run new users thought solving this issue. If you have this alarm and the filament indeed has been retracted then check to see if there is a small piece stick in the filament sensor. If the filament has actually failed to retract then check to make sure the cutter is operational.
