Failed to extrude filament error
Thank you very much! I had the same problem, I turned the magnet and now it works.
Thanks for the pics. I have had the same problem for a month. Have found if I unwind the filament roll a bit it extrudes just fine. Apparently, the spool turns tightening the filament. I have no idea why magnetic would suddenly be backward. Was there a firmware change that caused the problem.
For me it didn’t help. I tried that, result the same. Without AMS extruder works. Support doesn’t answer 4 days. Terrible
this worked for me. I made sure to use a sharpie to mark which side of the magnet was facing up and then flipped it.
Just started having the same symptoms but they’re isolated to slot 1 of the AMS. When I load any other slot, the print goes just fine.
I’ve started having the same problem. Thought it was related to some PLA-CF or PLA silk I printed. I’ve had to manually purge filament then start a print. The filament is pushed all the way from the AMS to the print head just fine, then pulls all the way back and tries again (3 times). I’ve never had the buffer apart. Why would a magnet flip fix it. Someone mentioned a recent firmware. Starting to get frustrated after I sent back my A1 for the X1C.
I have the same issue that you describe. "Extruding filament failed. The extruder might be clogged.0700 8007 …
I managed to make 1 3d print…No so easy as it is being advertised…
Made a ticket, looking forward to the reply.
I get the same issue in a print when changing filaments for supports. It worked for a week or so before, now I always get blocked nozzle errors or spaghetti failures after that.
When printing a single filament I get zero issues.
I’m having the same issue, I have two X1 and both stopped working at the same time today with this issue
Worked for me like a charm! No idea what’s the difference - both magnet’s ends seem to be equally magnetic. Red mark towards the spring makes the difference.
Quick update for me…
I thought about going down the magnet swap route. I removed a filament y-splitter (allows tube from AMS and external spool to be used) that I used for a few months to eliminate that as an error. As I disconnected the AMS buffer to start taking it apart I decided to try printing without the splitter just to eliminate that.
I plugged the buffer back in and attempted a print. Well, it’s been working perfectly for the past week.
I don’t think removing the splitter did anything. The filament was always making it to the extruder just fine. I’m guessing, and hoping, disconnecting the buffer may have reset some internal cache or something.
I’m printing from AMS using the stock routing (no splitter) and have had dozens of hours of printing and filament changes w/o issues.
Not saying this will solve everyone’s issue, but worked for me. And I didn’t have to disassemble the buffer.
I had similar symptoms with AMS and a non-bambu filament. the filament gets loaded up to the filament sensor in the mouth of the extruder, but then it was sensed as not going in, and retracted.
in my case it was a firmware bug, i was on 01.07.03 where the detection mechanism was added but likely tuned to be too sensitive.
i upgraded just the fw and it’s working again.
bambu NEEDS to push updates like these as MANDATORY to users to avoid them going through the same pain and make them feel miserable.
After updating to the latest firmware, I started getting the same issue, Failed to Extrude filament when AMS is used. After a few retries it works. Bypassing the AMS works 100% of the time. I doubt the extrusion gears need replacement. I can purge all day and there is no clog.
Here is a video : https://photos.app.goo.gl/MEfRbfZARFuLVNsq9
I disassembled the buffer and reassemble it and it’s working now. The magnet mentioned in a previous post had red dots on both ends.
I had the same issue and tried the suggested magnet fix above which worked for me.
Holy cow, thank you for this post. I have been having this problem for ages and never put two and two together that it only started after that firmware update.
I was always able to cancel a print job and then start it over immediately to get things to work, but that meant I couldn’t do any multi-filament prints.
After the firmware update everything finally seems to be working again.
I read through the release notes and I see nothing about this change or there being a fix for this problem.
Both my X1Cs stopped working at the same damn time same error!!! I pulled and rebuilt both hot ends 3 x each thinking i had horrible luck. Still the same problem. Now im rebuilding the buffer in hope it helps. I had skipped the updates but decided to just run them yesterday. This is absolutely insane rhat Bambu is breaking these machines with updates!!! Never again. Once i get a stable build back im never updating again. We will find out if random buffer rebuild helps or not… sigh…
Had the same issue on my new P1S with a factory new AMS.
I just had these issues, turns out the spring was slightly out of shape, catching the inside of the buffer mech. fliped the spring so the damaged end was on the intake side of the buffer. I damaged the spring when I first assembled the AMS (thanks chinglish instructions!)
