Failed To Pull Back Filament Error
If it’s at the end of the print, doesn’t it need to purge the cut piece from the print head? That error message reads that the issue is filament stuck in the head. It’s almost like it’s cutting it, pulling back the rest, and then seeing what’s in the head as an error…or am I losing my mind? If I pull the head, yank that little “tail” of filament out, reinstall the head and then click Retry…the error clears, so to me, that piece does need to purge since it appears that’s what is causing the issue.
