Failed to send the print job. Please try again. - Again and again
Hi there,
i have an P1P with newest FW and Bambu Studio it says no update.
Likely 3 Months now i have the problem that i need send the print job to the printer nearliy 10-30 times.
The error Failed to send the print job. Please try again. shows up.
My Computer is connected to my router with LAN and the Printer is connected directly to the router by WIFI, i have no reapter. Signal is full.
I think there is a Cloud connection Problem from my Computer to the Cloud.
I running 1 gbit internet connection at home.
Is there any ports or something that i can configure to fix the problem?
I running no anti virus (only microsoft thing) and running the MS Firewall.
I have an fritzbox 6690 with newest firmware
if you use “SEND” instead of “PRINT” it doesnt use the cloud and write it to the SD card…but then u hafe to start it from printer display.
i know, but i love to send the the prints directly and its a feature that should be working
Try setting your printer to LAN only mode. That removes cloud from the communication path.
this nonsense is happening to me now, and switching to LAN only just makes the printer undiscoverable
I am having the same problem. I save the sliced plate, save to micro sd card and start it at the printer. I properly ejected. the current micro sd card and install the card with saved slice plate. Light comes on and it just sits there looking dumb! I cycled the power, then start the print again from p1s front panel display and it’s a miracle, it prints just fine. I do not have 1 successful pint from Bambu studio yet!. What is going on!
Was there ever a solution to this? I have an X1C that I cannot send (or download videos) to/from. I thought it may have been a weak WiFi signial but after adding an access point near the printer, it still gives me these errors. Starts to transmit the file then after ~45 sec or so crashes and says “try again”.
I cannot understand why BL does not put an ethernet port on their machines.
FYI, I removed and reformatted the SD card. I can manually load the SD card and it works, but not through LAN.
Any fixes?
Welcome to the forum.
What firmware version is running on the printer and what version of Bambu Studio are you using?
Studio: 2.2.1.60
X1C: 01.10.00.00
Is your Access point dual band? The X Series printer will only work with a 2.4ghz. Having a 5ghz with the same SSID is known to cause problems.
Yes it is dual band, which many if not most are today. Is that the issue? If so when will BL fix it?
Often changing the SSID of the 5ghz network to something different than the 2.4 can solve the issue.
Currently the H2D/S are the only Bambu printers that can operate on the both bands.
May have to try that. If true, does not look favorable to BL ability to put out a product that can use industry standards. Again crazy they just don’t put an ethernet port on it.
Anyone know how to add an ethernet port?
I find this a bit ridiculous. I printed 6 times up until right now. Same file is open. Now it is failing. Printed fine the 6 times previously today. Same file is open. I did make a new plate, but should that really cause an error like this? With no changes to my printer or the Bambu Studio software, why would this suddenly happen?
Wait… error is with the Bambu Lab side. Something to do with their server. But still, I am printing from my own laptop to the printer. I shouldn’t need their server for a local print…
Hi, just seeing if anybody was able to resolve this.
I have been printing different files for the past few days all going perfect.
Today I started having the issue, Unable to send print. Gets to 30% I keep getting error -3030
I have reset my laptop, restarted my P1P, restarted my router, reinstalled Banbu studio, turned firewall off. All no joy.
Do have really good wifi signal also
My P1P is connect to Bambu lab as I can see it and control features in the Device tab.
Really annoying, I know we can put files manually on sd or over LAN, but if the feature is surposed to be there to make things a little easier when were not near our printers.
Any help would be appreciated
I was able to resolve this today by signing out of my account within Bambu Labs, and forgetting my printer. I then logged in and re-connected the printer to Bambu Labs.
