My Front housing is not working, fan is not turning on and light turns on when i turn on the printer and then never turns on again
Sitting there at idle, the only fan that should be running is on the main board. On some units, it’s not too loud and on others it is more noticeable. Mine is about the same as a small desktop pc.
The light is on a toggle. If you turned it off at some point, it will not come back on until you tap the lamp icon again. It may default to off when new, I don’t remember if mine was off until I turned it on or if it has always been on. I’m away from my printer at the moment so I can’t tell you where the lamp button is in the printer’s touch screen menus. It should be on the device tab in studio.
That could be. I’ve not paid attention to when the text is lit, it may only be while it’s actively printing.
I had the same problem when I turned on the X1C but when I started to print that was solved
