Farm management software
Ive created farm management software, its available on GitHub - TFyre/bambu-farm: Bambulab Web interface for multiple printers
Features include:
  • liveview
  • upload&print from SD
  • XYZ movement
  • sending custom gcode
Tested by the community on: A1 / A1 Mini / P1P / P1S / X1C
Does not require custom firmware or lan mode.
Video of X1C livestream: https://youtu.be/bnVeQuQQlvY
Video of P1S controls: https://youtu.be/NR7ZbUdtOnA
Screenshot of P1P & P1S below:
how long have you run it? what are the most common bugs? are there any specifics on its configuration for different BL machines?
Initial release was created around 3 weeks ago, you can check the history here on GitHub releases
None that Im aware of, if you find any, please create a GitHub issue here.
The X1’s stream does sometimes get stuck and you have to power cycle the printer, but thats something for BambuLab to fix.
All configuration options are available here in the “Printer Section”
So far theres only some sensors that are X1 specific, the rest of the features works on all models
You mentioned it does not require lan mode, but will it work over lan mode?
Yes, all connections are direct to the printer:)
Added batch / bulk printing feature
Tested on P1S farm!
You can check the demo video: Bambulab Batch Print
That looks great!
Are you plannding to add queue system?
Like add 10 files, pick color what should it be printed and just clicking to start next print?
Please create a gitlab issue describing the feature and include details about ejecting etc and i’ll check what i can do
This is great! TFyre, thank-you for your efforts making this available! I second piotrek91222’s request for a print queue and just added the request as a gitlab issue.
I just found this. It looks great.
thank you
Hi folks, Matt the founder of Printago.io here. You can hook up unlimited printers with our software, and there’s no downloads or Raspberry Pi’s required. We’re doing a commercial launch on Feb 1, where you’ll pay for concurrent job slots. 100% free until then, and afterwards you can still hook up unlimited printers and monitor them.
We’re adding more stuff like automatic color matching to your print farm as well.
