It would be great if there was a way to add the alignment pegs/shapes to models without the need to cut a plane. If the software knows it can split to parts, then it would be nice to have the option to add alignment shapes to those parts for printing the models in pieces and putting it back together exactly as was intended.
That already is a feature isn’t it? Google Bambuslicer / Orcaslicer Pegs
My ask is to have the pegs WITHOUT the use of the cut tool.
If you have a model, which you split to objects, and not using cut…I simply want to add the pegs to the parts.
Maybe I’m misunderstanding though. Are you saying I can use the pegs without actually cutting the model on a plane? I was under the impression I had to make a cut to add the pegs
Yeah I just verified, you need to make a cut to apply the pegs…which is not what I am asking for….
Possible workaround? Add a Modifier to your model, fuse it, use the cut tool on the modifier, add a peg to your main model, remove modifier?
Haven’t tried it. Just playing with thoughts.
