I would greatly appreciate an option allowing us to dim or disable the AMS HT displays when they are not actively drying/printing.
My H2D is nicely dark when not being used, but the AMS HTs in my otherwise dark office, to quote Rhianna, “Shine bright like a diamond…”
Perhaps sync the display wake times to the H2D display if someone wants to quickly see the temp/RH in them and otherwise go dark if not actively drying/printing.
Hi! +1 to dim/disable options for the AMS HT display.
Additional idea (optional): add a “Standby screen” mode that can show the current time (HH:MM) when the AMS HT is idle (not drying / not actively used). Ideally:
Default: OFF (keep current behavior).
Options: Show clock; or rotate clock + humidity/temperature every N seconds.
Brightness: respect the dim setting / allow very low brightness at night.
Time source: synced from the printer / app (Bambu Studio / Handy). If time isn’t available, fall back to current humidity/temperature screen.
Use case: the AMS HT is often in direct line of sight, and a small clock in standby would make the screen more useful without adding extra UI clutter.
I own an H2C that I never turn off. I have two HT AMS that keep the lights on. I want them to turn off when the H2C goes idle and on standby, and come on whenever I send a print job. Has this request been done? Has BL acknowledged it??? Come on BL!
