Feature Request: Automatic AMS drying cutoff based on humidity levels
I would like to propose a new smart feature for the AMS drying workflow. Currently, the drying cycle runs strictly on a timer. It would be highly beneficial to add an intelligent automatic shut-off mode that stops the heating process based on the humidity sensor curve.
Why this matters:
  • Energy Efficiency: Avoids running the heater unnecessarily once the filament is already perfectly dry.
  • Hardware Longevity: Reduces wear and tear on the printer’s components and the AMS structure.
  • Better UX: Users wouldn’t have to guess or over-estimate the required drying time.
I don’t believe this would be a viable solution to drying filament properly.
One would drive the dew point down in the system, shut off drying, then find the filament continues to release moisture, driving the RH back up. I would also submit that 15%, or even 10%, is insufficient for anything other than PLA.
On top of that, heating the AMS drives RH down without actually removing moisture. This is what the purge function is for, however once it cools that RH comes right back up even if it’s been purged.
The AMS would have to go through a heating and cooling cycle then sit idle while measuring RH looking for it to slowly increase while at a stable, lower temperature. Perhaps doable, but technically defeats the purpose by requiring additional heating cycles if it’s not completed.
Furthermore, there’s a huge time component to properly drying filament anyways. It takes time for water molecules to “accidentally” break free of their bonds in the plastic. Sometimes a lot of time.
Yes, of course some intelligence would be needed, and seems possible. For instance the AMS could try evaluating the remaining water content in the filaments by looking at the humidity rise/slope after purges, or by looking at the variations/slope of the humidity changes when the heating element is cycled, or using the humidity sensor in other ways. It seems to me like using just a timer is the best way to IGNORE the current water content of the filament. The spools could be just a little wet, or really really wet… I am suggesting using all available information instead of just guessing a time required. The mode/checkbox would be called “Intelligent drying” and could use the filament type to improve its actual intelligence :wink: One difficulty I can see is handling multiple spools that do not have the same initial “dryness”.
I changed the initial proposal to remove the suggestion that it would only be based on fixed RH target.
There are certainly some extra issues with the AMS operation, but drying to a humidity level is how I do all my drying. It’s in a standalone dryer though. I have used this method for over two years and not a single issue.
But what may be different (I don’t have an AMS2 - both are the original version) is I pull spools out of my dryer when they hit 19% humidity at 55C for PLA and 65C for PETG. The spools go into either Prakis or my regular AMS. But if I put them in a Praki with a hygrometer (no desiccant), they easily pull the humidity below 10% at room temperature - about 25C. For actual storage I put a pack of silica gel in too, but as a check, my dried filament routinely pulls below 10% at room temperature alone.
In my drying I use a low flow of dry air into a Sunlu S2+ filament dryer. I get the dry air by flowing room air through a silica gel column which may or may not be comparable to the active drying an AMS2 can do.
But as my filament cools, it transitions from giving off water at whatever rate (water is still coming off when I end the dry) to becoming essentially a desiccant. If filament is dry enough, as it cools, it can lower the RH more than the temperature decrease raises it. But if the filament isn’t that dry, obviously it might remain a water source.
I don’t know how things shake out with the AMS2 though, or what that would look like.
I would guess you could check out how it would work though by just running the dry function on the AMS2 until it hits a target humidity, turn it off, and see how it goes. I think everything may depend on how dry an AMS2 can go.
Again, I’m totally inexperienced with the AMS2 so don’t know how things line up, but drying to a humidity, maybe as long as it’s low enough, works great and I do it all the time.
For what it’s worth, this is the result of just ‘pre-heating’ my two rolls of PETG here for about 4 hours then shoving in regenned alumina approximately 3 hours ago.
If it behaves like the last time I did it this way, I will stay below “5%” until next week no problem.
Screenshot 2026-10-21 210003
