Feature request: Check build plate alignment when the door closes
I’d like to suggest a new option to have the machine check build plate alignment as soon as the door is shut, so it can issue a notification/alert before the user leaves the machine.
I am sure that the printer would have to do some other checks before, but I would assume this could be finished within 10-15 seconds and hopefully before the user leaves the machine.
Sometimes, other things are on my mind, especially when I’m trying to get a print off in a rush, and I end up missing the notification longer than I would like.
Would others find this useful? I would be happy to gather others’ input and add it to this.
An option on one of the screens could be useful, sure. Like the “read nozzle info” feature.
Personally I’d never us it if it fired on “every door close.” I might re-open/close the door for any number of reasons.
Most of the time it will probably need to home the head first as well.
Also, a quick look at the striped area on right front of the bed can give a pretty clear indication of plate alignment. Which is all the camera does for us anyway… :slight_smile:
-Max
I second @MaxThreeD here.
In my opinion, it will start to annoy me more than giving me any benefit.
All the lost time doing these checks doesn’t make up the lost time for the couple of accidental misalignments.
I also regularly close and open the door, and would be annoyed by the fact that I would have to wait out the sequence, or use the menu to cancel the procedure.
Misalignments in my case are rare, and a good workflow to position the build plate properly would be more effective.
I like the idea of- especially if on a new printer model it had some extra sensors to do the check instantly and maybe always show a red light whenever a plate isn’t correctly installed.
Also a way of more quickly checking what plate type is installed and ideally not even letting you kick off a print to the wrong plate type would be useful too.
Just stick something rigid to the front of the build plate or the inside of the door. If the plate is sticking out, it will alert you with an audible clang noise when you close the door.
I still believe that when you simply exercise a bit on properly positioning your build plate, you hardly get any errors.
The plate type check is something different. That could imho simply be checked by the Birds Eye View camera (when installed), as it can read the code on any height.
The side mounted camera can only see the code when the platform is high enough to get it into view.
So that option would be more interesting as long as it doesn’t have to start a lot of movement. I also see the risk of getting your hand stuck when it is making its rapid motions for the alignment.
NGL, I solved this issue after the first time I didn’t put it in properly by putting it in properly every time after. It self aligns at the back.
Just slide it in at a nice angle so the magnets dont grab until it’s seated at the back and then drop it and move on. The tolerance for this seems to be “give or take a little”.
The build plate scanning process is triggered by a gcode command, it runs as part of the startup process in a print.
Some printers also can monitor the door state and do stuff if the door opens during a print, but I’m not sure having it monitoring at all times is realistic or even possible as a gcode file isn’t running at that time.
I put the plate on and run my finger along the right edge of the plate to make sure it’s aligned. It’s habit at this point, and easy to start doing.
My H2C recently started giving me the plate alignment error even though it was inserted properly. I use a Glacier Pro and thought at first it might be causing the error and unless I purposely shifted the plate to the left by about 0.5 mm it would error out.
So I calibrated my cameras and inserted the plate using the back stops and the errors have stopped. Assuming you are properly inserting the plate and your cameras are calibrated you shouldn’t need to worry.
Not sure I’d want my printer to check every time I open and close the door,
Clearly, it would need some level of intelligence, so it wouldn’t happen all the time, and like all other detections, it should be easy to disable.
Maybe it is an opt-in check that pops up a 30-second prompt if you would like to do it. It could be limited even more by prompting at certain times.
As far as safety goes, if you set it to run automatically when the door closes, motion should stop when the door is open.
This would make many actions safer for the machine. As far as I can tell, nozzle swaps on the H2C happen without the check.
On a side note, I would love to hear people’s workflow for getting it right every time, and what alignment features the camera actually uses. Because on my machine, which is 1 month old, it is vision-aligned every week; the “correct” alignment requires covering the left hatches some and leaving a gap to the right ones.
I hold the front of the plate up off the bed so the magnets don’t grab. I then slide it onto the angled bits at the back of the bed and drop it.
The tolerance for misalignment is wide. It doesn’t need to be micron perfect. I threw it in there once at a haphazard angle without paying attention, forgot it wasn’t seated, started a job and had the alignment error. Once.
Never put it in there improperly again because it’s just so easy to get it right.
I do exactly the same.
Make sure the tool head is toward the rear and the heat bed is low enough to have space above the bed to make the angle.
Lift the plate high so the magnets don’t interfere.
Slide it against the rear tabs with just enough force so that it perfectly aligns.
As mentioned earlier, I maybe had a couple of misalignments in 18 months of use.
Ditto.
I found the thinner plates like Glacier are more prone to sucking down a little too easily, needing a steeper approach angle and more deliberate “drop” once the rear tabs are slotted. Once sucked down to the bed magnets it’s obviously harder to move around… I don’t try and just lift it off again fully if I’m not happy.
Anyway the two times the printer complained about misalignment were with the SuperTack and Glacier plates. 2nd time it happened I looked at the striped right side marker and noticed it was partially covered, at a very slight angle. Wouldn’t have affected the print. But now I just glance at that mark if I’m not sure the plate seated nicely.
In fact I disabled a few of the dummy checks like that in the machine g-code, in the interest of shaving some seconds from startups (like the silly nozzle type check… even when that nozzle will not be used!). YOLO! ¯\(ツ)/¯
As in with the vision encoder plate?
How’s that related to build plate alignment? Or you’re saying the printer is picky about the alignment of the vision encoder during calibration? Or is that a separate topic altogether…? :slight_smile:
-Max
(edit: I think) They are implying that a more accurate home position or corner seeking position might lead to a more accurate plate corner detection; I personally think that they don’t rely on the motor positioning like asking is the plate corner exactly centered in the camera when it moves to the corner etc, and instead just take a photo and look for specific visual features.
I have had no problems or weirdness installing the vision encoder plate into an H2D.
While they’re at it, they could make make the build plate alignment less sensitive than 0.5mm. My H2C is very sensitive. Sometimes it even fails after running a second print without moving the build plate at all … so maybe it’s more sensitive than 0.5 mm.
