When producing multi colour models in 360 I haven’t found a way to get Bambu slicer to automatically assign the correct colours to each 3mf or stl file - so I have found you need to go through the laborious and error prone process of assigning colours (or extruder numbers) individually.
I’ve created a workaround using Keyboard Maestro on the Mac - which achieves more or less what I am asking for - but it the functionality is already in the product and I haven’t noticed it - or could be added it would be great.
NB/ In normal prusa slicer when you import a multiple file model it assigns each file to a different extruder - which isn’t ideal - but with some careful file naming you can get it to more or less assign the colours correctly.
PS/ If anyone is interested in my KM workaround - screenshot of steps attached.
It relies on the extruder number in square brackets being in the stl filename and needed to be run from the ‘edit in parameter table’ pop up screen.
