Feature Request - Display build plate used for models saved to SD
I would really like to see build plate info saved to models sent to the sdcard.
At the moment unless you specify in the file name its a wild guess.
I save a variety of projects on SD for easy print but sometimes I forget which build plate i sliced it on.
Then it takes a few minutes for the printer to tell me if its the wrong plate.
Given that you take the time to give a good name to your files, you could deside a code for each plate and add it to the name. G for textured, P for smooth, C for carbon, etc until there is a way to do as you ask.
Yes thats one way and i have done that before, but i usually forget.
