Feature Request: Guided “Nozzle Swap Wizard” for the H2D
Hey Bambu team,
Love the printer. Seriously — it’s a hell of a machine. The H2D does everything else with polish and precision: auto-calibration, AMS management, bed leveling, filament tracking… it’s borderline magic most days. But for some reason, swapping nozzles still feels like a caveman operation compared to the rest of the experience.
Right now, you’ve got to remember the whole dance yourself:
  • Heat it up enough to clear the filament (but not too hot to burn yourself)
  • Manually unload or cut filament
  • Crack open the clip
  • Yank the nozzle while praying the magnet lets go
  • Clean off the strings
  • Pop the new one in
  • Reseat, relock, and then go run calibrations manually
It’s messy, easy to screw up, and feels completely disconnected from how refined the rest of the ecosystem is.
What I’m asking for:
A “Nozzle Swap Wizard” — just a guided utility that walks you through the process on the touchscreen. Nothing fancy, just smart and safe:
  1. Auto-heat to purge temperature
  2. Unload filament
  3. Move toolhead forward and light the area
  4. Step-by-step prompts: “Flip clip → Pull nozzle → Insert new nozzle → Lock clip”
  5. Detect reseating, cool automatically
  6. Run offset and flow calibration automatically
Done. No guessing, no fumbling, no half-melted filament plugging the works.
You’ve already got the logic and sensors in place to handle all of that. It would fit perfectly with Bambu’s “works like it should” vibe and make nozzle swaps as effortless as everything else on this printer.
Thanks for listening — and for building the most addictive machine I’ve ever owned.
Have you seen the wiki?
If you have, what does it miss?
If you haven’t, does this help?
Don’t worry, the Vortek is almost here; it will do it for you automatically, but just on the right side. I actually think that a lot of people will use it more as a ready-to-use nozzle changer rather than for multicolor prints.
I haven’t seen that, but I did glance at it from your link. Thank you. I’ll read through it more closely.
However, it doesn’t change what I’m asking for. I think I’m a good example of a particular kind of user. I started with a Rostock Max as my first printer back in early 2013. Since then, I’ve assembled and tweaked many different printers. I used to really be “into” the nerdy side of the printing itself. 12 years later, I’m over it. I don’t want to tweak, tune and fiddle with my printer. And I don’t want to have to scour the forums for answers when I have a question. In fact, I never want to have a question. I just want the printer to tell me what to do. I’ve noticed that it’s not too difficult to swap nozzles and I’d like to swap back and forth between 0.2mm and 0.4mm nozzles quite a bit. And i can do it, but it isn’t “obvious”. I’d like a button and an automated, step by step sequence of prompts to tell me what to do next. It just makes things easier. I want to think about my part design, not how to run the printer.
