Feature request: Load / Unload / Purge in the utility menu
I think it would be useful to place the following items in the utility menu:
Unload at low temp. – Heat up to about 240° and start an unload sequence with cutting the Filament, moving to the chute and pulling back the Filament. Useful for manually fed filament with the AMS-cable connected.
Unload at high temp. – Same as above, maybe at 280°C.
Load at low temp. – Move to the chute, heat up and start extruding for about 10 seconds.
Load at high temp. – Same as above at higher temperature.
Move to chute – Move the toolhead to the chute.
Purge at low temp. / high temp. – Extrude for about 10 seconds.
Wipe nozzle – Perform a nozzle wipe at the chute.
Can’t we do all of this now, other than wiping the nozzle and one-touch moving to chute? There is an unload and load button, and as far as I can tell it heats up to whichever temp it needs for the loaded filament. The purge button is currently about 5 seconds, but you can push it twice.
