Feature Request? Multiple Models
Is there a way to add multiple models to 1 build plate in MakerWorld? For instance If I want to maximize my printing and will be away for awhile, can I add different models from different users to print at 1 time? Essentially adding models from different folders in Studio, they’re different users while away from the desktop and printer.
You can start with one 3mf file in Bambu Studio, and then add other 3mf files onto the same plate - but it won’t bring in the slicing attributes for the added 3mfs - so they will have to be manually set at the moment,
I agree it be nice if makerworld could automatically merge 3mfs onto a single plate for you - as long as the layer height matches.
I appreciate your response!
Yeah, I get what you’re saying Studio. All it would have to be is a save plate function prior slicing in order to add more models.
I just don’t want to print 1 at a time and have to wait until after work to clear my plate so I can start another print. Maybe I can add some scripts to knock off my models before a new print can be started. :rofl:
Agree with your request.
I find two interesting pokemon coins and want to print them on one plate, but bambu studio does not allow me to copy and paste.
You can import the second 3mf file by simply Drag’n’Drop it onto the plate. You then get asked if you want to ‘import the geometry only’ which you should.
