Feature Request: Rotation & Scale
I’d like the ability to +/- 90* on rotation with a button click versus having to move it with the sliders or manually type it in. It’s easier for me to click a 90* button until I get it where I want it versus knowing it’s 180 or 270.
Also for scale, an old slicer I worked with had a “maximum” button so you could build it to the max of the build plate. I’ve used it quite a bit when modeling stuff and wanted the largest that could fit without dragging it out.
Agreed. 99.44% of all rotations anyone will ever do will be 90-degrees. Another possible solution is to expand the align to printbed option to allow aligning on the other two planes.
Not if you are printing miniatures and/or action figures. The dials make it easy to rotate the parts for better orientation.
pageup/pagedown can rotation 45° (on z axis),The cursor moves to the center line,
can also be rotated 45° .
For maximum scale, you can click Scale to change the length of the long side to the maximum value of the heated bed.
