For projects with many build plates, it would be very helpful to sort the plates by estimated print time.
When a project contains a large number of plates, manually checking each plate to find a short or long print is cumbersome.
A simple “Sort by Print Time” option, both ascending and descending, would make managing large multi-plate projects much easier.
This would require slicing all of the plates also.
I actually don’t know what you mean
The only way to know the estimated print time for a plate is to slice it. Let’s agree to that first.
You can already do “Slice All” - and it gives you a summary of the the print times for each plate.
I think, what would be more useful is after a plate is sliced, show the print time and total filament usage for that plate on the Prepare screen - which would be helpful for both Slice All and for slicing individual plates.
Well, yes, of course after slicing. How Else could there be an estimated time.
I mean sorting them after slicing , so you can plan your print.
Would’nt make much sense for 4 plates but for this it would be nice.
The issue with your proposal is it only makes sense in a very narrow set of circumstances. It requires lots of plates - because to your point, it’s less useful for fewer plates.
BUT - a lot of plates with big print jobs doesn’t work either, because Slice All would take hours in some circumstances, and nobody wants to wait around for that.
A feature request that brings benefit to the greatest number of users and scenarios is going to be far more likely to be produced than one that helps in more limited circumstances - especially if there’s already something there to help with the situation.
FYI - I just finished a 62-plate print project (700+ print hours) and what you’re asking for wouldn’t have helped me at all. Showing print time/material next to each plate, which I could then rearrange myself using the move plate command would have been more helpful.
Are you selling prints, or do you print as a Hobby? Would make a big difference.
For me, i’m using the p2s as my hobby, i never had anything that required more than 1-2 minutes in the slicer.
But, for me, planning multiple build plate prints, so it can print over night and it being done before i have to leave for my Job, is much more important.
