Feature Suggestions
I would very much like to be able to set temps to 0 if the print is paused. The last thing I want is to have the nozzle half heated while a print gets paused for hours on end. Waste of power, and potentially dangerous.
I would also like to have the option to switch to a different filament color on the fly, maybe with a confirmation prompt or something. For example, I was running a print with some leftover rolls of Grey PLA. The first roll finished, so the AMS switched to the second. However, the second roll seems to be having a problem being loaded with the AMS. I am not near my machine, but I don’t mind if the print finishes in an entirely different color, such as the Blue PLA that is also in the AMS. No, the print wasn’t sliced with the Blue, but if all of my Grey is either used or indisposed, I want the option to continue on with a mismatching color if I so desire. Like I said, maybe an “Are you sure?” prompt could pop up while making this decision.
All of this culminated in me having to cancel my partial print. I couldn’t switch to blue from grey to finish out the print, and because I couldn’t lower the nozzle temp below 145 (the “resting” temp I guess), I had to fully cancel the print instead of just leaving it paused. Obviously this is a waste of time and material, and it all could have been avoided with just one of the two features I’m requesting.
Thoughts anyone?
Regarding the switch of filament in the AMS:
until a better solution is in place and you are near your printer what you can do is take (e.g. the blue one) out of the current slot (no need for unload as it is currently not loaded) and feed it into the current slot used for printing. This ‘fakes’ the AMS you refilled the current slot and continues printing. Did it myself a couple of times already.
Since I am color blind I would like to see the names of the colors when having to select one. Also we need more choices of colors.
I use a Bambu X1-Carbon at work and frequently I find myself starting prints that will run over night. Some of these prints involve using support material for PLA or even PVA. I have learned that this support material is much easier to remove when it is fresh off the printer. Because of this, I think a feature where you can schedule when a print starts would be beneficial. Currently, I have to start a print, then pause it in the beginning and then remember to start it so that it finishes when I come in to the office in the morning. I believe that this feature would be pretty easy to implement and would be useful.
Please let me know if I am missing this feature in bambu studio, but currently I am facing an issue where I would like to decide when I have a support interfaces on my 3-D print. There is a portion of my 3-D print that I would like to say uses entirely PVA support material to build the support (not just the interface material) since it pertains to a small gap that is hard to remove the base material from (PLA). There is another portion that I would like to have PVA as just the support interface, and then use the base material (PLA) to build the support, this will allow me to reduce the changeovers between the 2 filaments and save time and money. It would be nice to have a feature that allows me to decide where I want a support interface and where I don’t. Again, please let me know if there is a current method that I don’t already know about, but this seems like something that could be implemented fairly easily.
Id like to see a feature added to bambu studio where when you view your print history and for example a camcelled print. Id really like the ability to see what layer the print was cancelled or stopped on so instead of restarting a big print i could cut the model to the layer it stopped on and just print the rest of the peice to glue together. Maybe along with this a tool to be able to tell the slicer that you want to start a print at a specific layer would be awesome. Ive had power failures and when I hit resume after power comes back it doesnt always resume and then im stuck with a partial print after 15 hours and have to try and make my best guess as to where the model ended to try and print the rest instead of completely starting the print over.
I came here to suggest scheduling, like @RAMCO_Engineering mentioned.
A short story of the use-case: When we finish dinner, I typically do the dishes. I load everything in the dishwasher… but I know I’m going to have a glass of milk and a few cookies later so I don’t start the dishwasher. I know I’m going to sit on the couch and probably fall asleep… and totally forget about the dishwasher. Tomorrow morning I wake up with the unwashed dishes.
But now… I use the delay timer on the dishwasher so it starts at 3am. So if I stay awake and responsibly put my dishes in the dishwasher… great! But if I fall asleep… no problem. that bish is cleaning the dish.
If I could schedule a print to start later… it gives me a chance to add more pieces to the plate if I think of something I need.
Sorry for the rambling :wink:
I’d like to see the two long slots on the A1 to be covered with brushes, foam, or flexible strips to prevent dust and filament scraps from getting in.
Feature Request - When the printer is running, during start up, it shows the various stages on the screen. i.e Cleaning nozzle.
Could you also do this during printing, where if it’s switching filaments, or cleaning the nozzles/extruding for change, etc, it shows that, instead of just ‘printing’?
Feature Request - The ability to select which filament is being used for infill during slicing.
My thinking is this - I’m printing out an object in Red, White and Blue. The base color is white (Filament 1), with red and blue details.
To me, it would appear that being able to say ‘just the walls have been painted, the rest has not been’ could save on filament changes, and therefore save both time and purged materials. Being able to select sections and doing this would be even more useful.
Especially since some objects are mostly infil material anyway.
Feature Suggestion
Allow the AMS 2 Pro’s to initialize non rotation drying automatically past a certain humidity. For example if it reaches 20% or 25% it auto turns on for a 12 hour and it would check for pla, petg, abs etc and go with the lowest temp one. And if we start printing with that ams it just auto shuts off. I would love to not have to constantly manage them. Also it would be great if it could start drying if it’s plugged in while a print is going. I had a 24 hr print and wanted to start drying an ams not in use 12 hrs into the print but couldn’t as it was busy. Even if I have to pause it that’s just a waste of time. it’s plugged in lol.
support évolution!
three support is nice but
cannot add svg on, or choice modele of
like
wind, sea as it with transluciant filament or??
customise it
c’est pour cette raison que me demande pourquoi
on prerender
why cannot have access to button of modelisation !
will be great, just code
new feature that whenever you start a new print you can push off the print to a bucket where it will fall. also make it work with the prime tower and the thing thats one layer at the front. would be really usefull if i need to print something and i am away. could be useful for many other people too with the same setup as mine.
this will of course be optional for people to use.
Welcome to the forum!
There’s a mod that I think would do what you want…
hey. i forgot to mention but this is for the A series.
Oh, in that case there are several mods to do it…
https://makerworld.com/en/search/models?keyword=A1+automation
may i suggest to have a maintenance mode to lube the lead screws so the bed goes up and down then we can just apply lube at one point of the lead screws then it will auto lube the screws
you can see that all be separated by color, with wall and each fill motif inside!!
but how can i made one fill motif for all this piece!! have translucide inside too.
AND or OR
how can i made different motif by color!! it’s
ONE PIECE, but kyubi represented from
image to 3d modele on markerlab!! give like this now with new humaid!
but , cannot simplify it or remove all color and same
insert objet or remove part from!!
Hi Team.
A feature I’d really like would be to be able to make my camera full screen. I’d love to be able to view the video of my prints in full screen!
Keep up the awesome work crew.
Matt.
