Few question
Hi there.
I got a x1c and I’m thinking of selling to buy the x2D, but I have some doubts.
On the X2D, is it not possible to turn off the auxiliary and external fans?
Does anyone know the power consumption of the X2D with a cold plate, and if so, is it possible to turn off the fans?
In terms of noise, which one is the quietest? I’m only considering the printing process, not color changes.
Thanks
At minimum, it is possible via G-code, but with custom machine and filament profiles, it may be easier to achieve.
Take the total wattage rating of the printer and subtract the wattage of the print bed. There’s your answer. The fans don’t meaningfully impact power draw. The printer may also have a low power mode, you’ll need to verify that though.
Which one what? Which printer? Find the one with the lowest dB rating. You can also do a lot to make a printer quieter.
