I am doing research on my first 3d printer and came across the Bambu X1 Carbon, which looked to be a well made and easy to use printer.
I have started to dig in on a variety of forums on folks ( hopefully ) honest opinions and reviews about the machine which added more confusion as there’s more “horror” stories either with printing, rust, or inability to get support.
I then came across another unit, a Qidi Max3 while searching and I saw that it has an internal heater and larger bed size 12x12 and a way to keep the filament dry vs 10x10 on the X1C, but no AMS for color swaps. ( not sure why you would need to keep plastic dry, is there any particular difference with these filaments that attracts moisture that it needs to be dried? )
I then researched more and found that there is an aftermarket closure heater to keep the inside temps around 55-60° C or so to prevent warping, so I could possibly add that and have all my bases covered for successful prints? Though I am unsure if the heater would cause issues by adding it since BU did not include it?
I’ve also come across some posts over on the BU forums saying that the AMS unit has feed issues and it’s a pain to fix and that it happens often. I understand there could be issues with any new tech but I’d be curious to know if the AMS is really all it’s stated to be or if it’s still a problem?
With all the above said, it’s of course obvious that one will not know until one gets something to form a baseline. This is how I approached my first CNC laser engraver, and found out the pros and cons myself.
With the 3d printer I’d like to do it right and do it once rather than go after machine after machine, though it seems that this changes with new advancements in the tech more than a CNC laser cutter/engraver.
My aim with this is to spend more time designing rather than fiddling with the printer which is part of the allure of the X1C, I only got confused with the lack of heater and smaller bed size ( not that I want to print a helmet or skull but having that capability is nice )
Could anyone weigh in on the lack of internal heater, pros/cons on the X1C or any of the above?
I’d like to make some headway on which path to take.
Many thanks!
