Hi, I have a suggestion for the auto refill, you could make it so, when the popup is triggered, you would be able to chose which filament to replace it with, this would be available for every filament, that is in the same temperature range, and would work like multicolour (this means, that the only thing that it would be checking is the temperature range stated in filament settings). Also there could be a warning popup when you would chose a filament that is a different type, brand, colour, but this would just warn, not enforce you (this means, that you could just ignore the popup and proceed).
This could be toggleable in the settings.
would really appreciate this, because when I print a model and I don’t care about the colour, I just want to finish it with the filament available, right now, I either can’t, or have to trick the printer to think that it is the same colour.
