The filament buffer is crunching continuously. The noise is more like a squeak.I tried the same thing as jonathan.meyer29, but it did not work. Every time the Spring / indicator goes to empty on the way its squeak.
Carefully apply an incredibly small amount of silicone grease to the moving part. That’s what i would do.
did you found any solution? mine started yesterday… Its squeaking when unloading filament.
I just unscrewed it (the filament buffer) and moved all by hand
and then screwed it back, and it works with no squeaking
it stopped after 1-2 days…These weird sounds that comes and go are giving me headaches.
ptfe oil is magic…More letters because the forum has a minimum of 20 per post.
