Is there any way to see the linear advance and other parameters set by the LiDAR calibration?
I think, but I’m not sure that the textured PEI bed affects the filament calibration in a bad way.
I’d like to compare the calibration numebers when done on a smooth vs textured sheets with the same filament.
Since updating, and running the textured sheet, I am getting terrible seams, and I think it’s related to the calibration.
As far as I had understood, LiDAR calibration doesn’t really work with the textured PEI (this is the reason they ship the X1 with the cold plate).
It would be cool to get the values of reading - or more feedback - but as far as I understood, you should not use the calibration in combination with textured PEI sheet.
It would be good to get official confirmation on that from Bambu if an Admin reads this.
This could be prevented in bambustudio, but graying out the flow calibration if the textured plate is selected.
Does that mean to get better results, I should just turn it off? Or do I need to run it with a smooth plate with calibration to get a good result again.
The official word is that the Lidar doesn’t work with textured plates. They have said many times before. I don’t use a textured plate as I see no need. I print primarily ABS on the engineering plate with no issues.
