Note that when I try to print there is an odd error indicator on ABS filament. But when I look at the device, it looks fine. But at any rate, I can’t click PRINT. Anyone knows what is going on?
Looks to me like you’re trying to print ABS where there is no ABS in your AMS. Either re-slice to use PLA or install a spool of ABS in your AMS.
Ah. Well what I have is a spool of TPU in the first slot of the ABS. But then why is the print dialog saying ABS, which indeed I dont have and have never had?
Solved: For some reason in the other pane, slot 1 of the TPU was set to ABS. I don’t remember doing that but there’s no one else here… So my error.
It could be for various reasons, but ultimately you’ll need to re-slice using the TPU you have, sync (or re-sync) your AMS with the Bambu slicer and the TPU will show up as an option for the filament to use.
