Filament choose
Help, what consumables should I choose for Garage Kits? How to solve the problem of rough surface of the model?
There are differences, but many filament materials and models permit to achieve an excellent surface.
What are your print settings, nozzle size, current filament material and if it dried?
I would start by checking these details before assuming it is the filament (it can be) unless there is an apparent reason for believing that.
微信图片_20230613115826
Thank you for your answer,I have only recently started using this device.Used complimentary materials. What are the settings that can make the surface of the model smoother?
I cannot see your settings from the image. Yet:
  1. The white filament is a support filament, and the green is PLA. So you printed using a support material or using the settings for support. I am surprised that the print stands. If you change this, you will get a completely different outcome.
  2. Regarding surface quality, the most trivial settings are layer height (smaller ones advisable) and, if possible, using a smaller nozzle. Nevertheless, 0.4mm is a good size.
    Reduce printing speed, at least for external surfaces.
  3. Further improvements require fine-tuning the printer and filament, for example, the “ideal” flow rate.
  4. Besides these, post-processing.
I almost forgot the model quality needs to be adequate for the desired print quality. This involves modelling an object, which is a quite an extensive topic in which I only have experience with functional parts.
