I keep getting the error “the filament cutter sensor gives an error.”, well I checked the cutter, reasembled it on this almost new A1mini, but no luck, After upstart, I can unload and load new filament, but then it stops at “the filament cutter sensor gives an error.”
I think that the sensor is located on the same board as the filament sensor but is triggered by a small round magnet on the back of the cutter lever, check if it’s anything wrong with it . Also check if the lever makes a whole trip(the screw could limit a bit the lever)
